Where would they be located?
Probably near the flyback, possably on the conv board.
Sony marks things well so look on the conv board for the voltages. Start at the harmonica connectors. There may be other voltages coming in like 5V, 9V, 12V to run the rest of the board. If it has resistors they will be abt 1 ohm 1 watt. The coils may look like small white rectangles with wax on the top, at least on the older ones they did. 73 Zeno
What letter would be on the board cause they are all labeled.
I was thinking of measuring the voltages IF the IC's dont
fix it. 73 Zeno
Right. im not familiar with convergence so I'm wondering what letter it would be. Main power board is "A" and video section is "G". Those are the two biggest boards in there. Then there are CG, CR, etc. I don't even know where the thing is.
OK I get it. Dont remember what the letters were. It will
have 3 big IC's all the same on heat sinks. Maybe someone has a manual ? 73 Zeno
Update: I guess it is the STKs. There's two and they're big. Problem is, the spares i have from the 48" are stk 392 110. Will 110 replace the 150 or no? Last edited by pac.attack76; 10-25-2014 at 06:01 PM. |
