Old 10-24-2014, 05:26 PM
jstout66 jstout66 is offline
Which RCA TV used this remote?
I've had this remote laying around forever. With the Accumatic control, I'm guessing CTC-46, but does anyone know for sure?
Old 10-24-2014, 05:44 PM
I would guess abt 1970 almost definately an early solid state.
If I get bored this weekend I will scratch through a few Sams
& see if I can spot it. But I gotta feelin my squaw wont let
me get bored !
Old 10-24-2014, 07:31 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
I have two of those, one within reach. I'd like to know as well. Considering the look of the channel switch on that one, it was used by a real couch potato.
I just remembered the ad I have that shows this remote. I've seen other ads that show remotes with the same shell but fewer switches, but I don't think they were remote sets.
Old 10-24-2014, 07:39 PM
Does it have a CRK number. Probably in the door.
Old 10-24-2014, 08:02 PM
Jon A.'s Avatar
Yessah, underneath the back cover. Only the bottom cap needs to be removed to access the battery compartment. CRK14C.
Old 10-25-2014, 08:01 AM
Findm-Keepm's Avatar
Followin' the Rules...
CTC40 remote sets used a similar one, and the XL-100 pictured is probably a CTC44 chassis set. GR series were the first year of the XL-100 (MAD/MAG/MAH/MAL), IIRC.
When you ordered a replacement from RCA, it was always "reconditioned" - no new remotes were made beyond initial production. The remotes came with a reconditioned sticker and a little sheet telling you the remote was used. Many had deep scratches - some customers were appalled that the remote they turned in was better looking than the one RCA supplied. I have one of the same remotes, reconditioned one with all the nasty scratches in the case.
Brian
USN RET 22YRS (Avionics/Cal)
Old 10-25-2014, 09:59 AM
I bought one a few weeks ago, from a thrift but it has only two rocker switches, volume and channel, plus the on-off button on the side. I thought it was for a black and white, or a lower end color set. It only uses one AA penlite cell.
Old 10-25-2014, 11:59 AM
Probably a hotel remote - they didn't give guests the opportunity to change Many settings. I have one that says mural tv on it -RCA's hotel/ motel models were all mural tvs.
Brian
Old 10-25-2014, 12:57 PM
Jon A.'s Avatar
I've seen plenty of these remotes with 1, 2 or 5 rocker switches as seen here. The side button might control power only, channel only, or combine power and volume.
