Old 10-30-2014, 11:34 PM
rca2000's Avatar
rca2000 rca2000 is offline
Originally Posted by CoogarXR View Post
PS- Just so you know, "panel" refers to the screen ("LCD Panel"). The things inside are usually referred to as "boards". Power Supply Board, Main AV Board, Etc.
If there was a "snap' noise from it--that sounds like perhaps an SMPS or inveter issue. BOTH not a hard fix--the SMPS can be repaired--the inverter should be available on ebay from a cracked panel set.
