Old 11-01-2014, 12:59 PM
yes the crt is dark but still see the drive lines and i already checked the pots and they are in range. when i put the jumper back i will be able to adjust the hv but what is going on it struggles to regulate yet i can get it adjusted to 25kv but with the hv pot maxed. so ill have to check the voltages at the crt and hopefully ill get somewhere there.
do this, check the HV with a probe with the CRT brightness all the way down, does the HV pot adjust from say 20 to 27kv? If it does the regulator tube is working.
now set the HV to 23kv with the brightness all the way down. READ the shunt tube current and let me know what it is. Based on what you get I will tell you what do do next.
