Old 11-29-2014, 08:37 PM
Originally Posted by Kamakiri View Post
No, it's actually marked 30K.....I didn't test it.
Not shown in the schematic that I have for what appears to be the same (or similar) set (PF set 126-folder 5) nor as an indicated substitution/modification... where does the other end connect?
Old 11-30-2014, 11:10 AM
I was just looking at the schematic again. In the picture, the vertical linearity pot is a rather high wattage type. The 470 ohm resistor seems to make sense, even if the pot is turned to minimum resistance, there is still bias on the cathode. I also notice the 6K6 is triode connected. I would restore the circuit to original, per the schematic.
I find it strange, that some of the vertical circuitry is so far away from the sweep tubes. Rather complicated set to work on, plus the wiring is like a rat's nest.
Old 12-01-2014, 06:48 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
For the moment, I'm going to assume that the last guy who had this set knew something about the components that I don't, and replaced some stuff or something that required the caps and resistors that don't show up in the schematic. I mean, you usually don't throw what looks like expensive high-wattage resistors into a set without a good reason, right?
You're right though, the wiring is kind of like a rat's nest, but I've dealt with a lot worse. My plan at the moment is just to finish up recapping, and see where we're at. After I got everything hooked up that wasn't, and got a lot of the caps in, I pulled the 5U4 and bench tested the chassis to see if the transformer was good. Ran nice and cool and all the tubes lit, so that's a good sign.
Old 12-02-2014, 05:00 PM
Kamakiri's Avatar
It goes to the yoke socket for the picture tube. This is Sams 126-5, same as yours.
I have to say that the quality of this set compared to others I've worked on of this era isn't anything to write home about. Cheap parts, crappy sloppy wiring.
Old 12-02-2014, 05:32 PM
What pin #? ... Perhaps we can reverse engineer the resistor connections and figure out what they were trying to accomplish.
