Old 11-30-2014, 07:38 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
Zenith 23XC38Z Chassis Losing Horiz. Width
Hey everyone,
My daily watcher 1967 Zenith with the 23XC38Z chassis has been slowly losing Horizontal width at both edges of the screen over the past few weeks, however, the shrink has been much more noticeable over the past couple times I've had the set on. It gets about 2-4 hours of use a day, five days a week, and Ive been in using it in this capacity since about 2011. In that time, I've replaced a few bad electrolytic caps, the focus rectifier, a horizontal output tube, and a Damper tube. Does anyone who has any familiarity with these late 60's zenith Tube Chassis sets have any pointers on where to look for problems with Horizontal Width on the 23XC series chassis? Any help would be greatly appreciated.
I've been putting off pulling the chassis to install the NOS Channel Master Rebuilt 25GP22 I picked up a few months ago. It looks like this problem gives me a reason to get off my butt and finally do that.
Thanks in advance.
Old 11-30-2014, 08:24 PM
The first guess would be a weak H output tube of couse. There's a 'quick and dirty' way to check it without subbing the tube.
Turn the set off for about 7 seconds, and back on. Does the width take a while to fill back out to where it was, or not? If it does, it's likely the H out tube.
(The '7 seconds off' test can also reveal borderline weak H osc., 3.58 color osc., Vert out, RF amp tubes, etc.)
Your set probbaly uses a 6BK4 HV regulator. In later Zeniths using beam triode (6HS5, 6HV5 etc.) regulator, a gassy regulator can cause loss of width. The only test for these is to sub the tube, even though it tests 'good' on a tester.
Old 11-30-2014, 08:34 PM
fsjonsey's Avatar
I subbed in a spare NOS 6JS6C tonight and unfortunately it made no difference. I also swapped the damper tube.
Old 12-01-2014, 01:34 AM
fsjonsey's Avatar
The first guess would be a weak H output tube of couse. Your set probbaly uses a 6BK4 HV regulator. In later Zeniths using beam triode (6HS5, 6HV5 etc.) regulator, a gassy regulator can cause loss of width. The only test for these is to sub the tube, even though it tests 'good' on a tester.
This set uses a 6HS5. I subbed that with a NOS one too and it made no difference. I'm guessing a cap or resistor somewhere. The Horizontal oscillator is part of a 6u10 triple triode compactron. I subbed that too. Basically, I did all the easy stuff first hoping for a low effort solution.
Old 12-01-2014, 06:25 AM
Looks like all left is the damper. Also there is a VDR in
the HV reg that causes a minor width problem. On newer
sets HV control gets a bad spot but also only causes minor
problems most would ignore. Power supply also poss.
but you should get hum bars in that case.
BTW the OEM Zenith VDR's are going bad on the shelf.
There is a sub for it, was talked about a few months ago.
Since you will be pulling it probably best to replace it and
the 2 vert integrators, all high failure stuff.
Old 12-01-2014, 01:24 PM
Your set likely has a width jumper. It should have two positions 'increase' and 'normal'. Move it to increase if it is on normal. If that don't help, and the HOT is still strong, then you have a definite problem.
Old 12-01-2014, 02:34 PM
I would start by checking the B+ and HV
Old 12-01-2014, 02:39 PM
note this set uses a voltage doubler, so if B+ is low I would start there. Also while I doubt its a problem, there is a Thermistor in the B+ circuit, just in case you may want to check the voltage drop across it after it warms up.
If the cans are orig, see if they are warm (remember on doublers one of the cans while have voltage on the case with respect to the chassis, should have a cardboard cover).
Confirm line voltage ok (I go to the easy stuff 1st).
If B+ is ok then I would start checking voltage on the 6JS6 tube mainly the control grid voltage (-60v)and the screen (135v).
other things, are those large white tube caps, think at least one is a boost filter cap, maybe leaky if not replaced already. .1 1kv could be loading down the fly.
Old 12-02-2014, 08:59 PM
fsjonsey's Avatar
Bingo!
The caps on the doubler were going south. I'm going to go ahead and replace them and the last of the other electrolytics I haven't replaced yet. Thanks for the help guys!
Old 12-03-2014, 01:34 AM
fsjonsey's Avatar
Also, does anyone have a service manual scan for this chassis? I want to get all the cap values so I can buy the caps in one shot.
Also just an FYI but my local electronic surplus house just got a big load of NOS Thordardsen Yokes and flybacks for various tube color sets from an extinct contract service center that used to do repairs for major department stores in NE Ohio. I was able to grab two spare yokes and a spare fly for this set for $30, and I talked the owner into holding onto the rest for a while and not selling the lot for copper scrap. Just thought I'd let you guys know.
http://www.electronicsurplus.com/cat...?q=+THORDARSON
Old 12-03-2014, 06:47 AM
Findm-Keepm's Avatar
Followin' the Rules...
Alas, the usual criminals are missing: Fly277, Fly308, Fly312 -all of RCA's most vulnerable. Still some goodies to be had - cheap too!
Brian
USN RET 22YRS (Avionics/Cal)
Old 12-08-2014, 02:35 AM
fsjonsey's Avatar
I pulled the Chassis tonight. It was much less of a chore than I had anticipated.
Tomorrow I'm going to replace the rest of the electrolytic caps I haven't already replaced, install the NOS 25GP22 rebuild, and do the convergence and setup.
If anyone asks, that's a last gasp 1978 Portacolor peeking in the right side of the frame. It has the stripe Phosphor tube and click-stop UHF tuner. I've been using it temporarily because I've been too lazy to dig into the Zenith for the past few days.
Old 12-08-2014, 09:28 AM
the plug in tuner makes it a easy chassis pull. Its going to look great with a new CRT. watch out for the little black electros with red tops.I had one of those go one me in the AGC circuit, made it HYPER touchy in the adjustment.
Old 12-10-2014, 02:56 AM
fsjonsey's Avatar
I put this off for days thinking it would be a massive project, but Zenith really designed this chassis for easy servicing. It took less than 30 minutes to pull the chassis. Zenith was smart enough to emboss all the chassis connection points for the power switch, degauss coil, speaker, etc.
DaveWM: Thanks for the advice, I'll look out for those little caps.
I'm still amazed I got almost four years of regular use out of this set, with mostly original components. It was still hooked up to a digital cable box and plugged in when I removed it from it's original home in a Duplex in the Collinwood neighborhood of Cleveland back in 2011.
Old 12-10-2014, 07:43 AM
And if you pull the tuner there is a few spare screw on the back to mount
it to the chassis. RCA also did it.
Our first color set was one of these ( or a Y line). Got it for the '67
world series. Under warranty a rectifire shorted but after that ran
til abt '77 no repairs. Sold it used & only replaced the 6HA5 RF
amp to perk it up.
NOTE when changing a 6HA5 try to find the short envelope version.
For some reason all the "tall" ones were noisy, enuf to kill a deep
fringe signal or make a fringe station grainy.......
