Old 12-18-2014, 03:08 PM
tvcollector's Avatar
Parts are about to arrive soon.. I've got a few questions before I attempt all this:
I have a 50volt 0.47 electrolytic cap somewhere I'll have to dig up.. Will this work ?
How do I connect the cap? poz and neg leads from tester or in series on the red lead?
Old 12-18-2014, 03:39 PM
Findm-Keepm's Avatar
Followin' the Rules...
No, use a film cap across the meter terminals - a .47uF at 600V is sufficient. If you need one, I can probably find one this evening and get it in the mail to you.
Brian
USN RET 22YRS (Avionics/Cal)
Old 12-18-2014, 03:41 PM
Ya.. I don't have film cap...That would be really nice of you to do that...
Old 12-18-2014, 03:57 PM
I'll get one in the mail.
Meanwhile, a repair article discussing the cathode current and horizontal output stage in a tube set:
http://www.americanradiohistory.com/...-Page-0084.pdf
Why do you bypass the meter? The inductance of the meter can affect some Horizontal Output stages, causing failures in other areas.
http://www.americanradiohistory.com/...-Page-0061.pdf
Cheers,
Brian
Old 12-18-2014, 04:13 PM
You connect the cap in parallel with the meter leads. And since you are (and should be) doing this with a film cap don't worry about polarity of the capacitor (since film caps are non-polarized) .
Old 12-18-2014, 05:48 PM
Thank you both for the info.. I'll let you know the results once do the adjusting and measuring.. According to the Sams, the current must not exceed over 215ma..
Old 12-19-2014, 09:51 AM
I'm trying to remember, if the set uses the 6HF5 or the 6JS6. I know some GE's used it, as well as some Zenith's.
Old 12-19-2014, 12:28 PM
Yes to both. The 6JS6A is a replacement for the 6HF5. IIRC, GE marked them as such.
Cheers,
Brian
Old 12-19-2014, 12:45 PM
I just got my HV probe, I turned the set on and probed under rubber cup and the needle of the HV probe only went up a digit before the 10 mark on the meter.. Meter shows a red line in between 20 and 30, I think where the needle should be.. Not sure if the meter is reading correctly..
Old 12-19-2014, 01:06 PM
try it on a working set...
see if reads correct then....
If not then the meter is prob not right.....
Old 12-19-2014, 01:21 PM
I tried it in another working set, and the needle is bouncing around, though in the higher digits.. Even got a slight jolt of static electricity while sliding the on switch on the probe..
Old 12-19-2014, 01:26 PM
did you attach the ground lead to the chassis?
are you sure you are getting it on the anode and not arcing under the cap?
Old 12-19-2014, 01:30 PM
I didn't attach the ground to chassis.. I wasn't sure if that was for just discharging a crt.. I hear a zapping noise when I do that, but it looks to be touching the metal anode under the cap.. It's also touching the lead from the flyback and it looks to be effecting the reading too..
Old 12-19-2014, 01:32 PM
attach the ground clip before you hurt yourself.
Old 12-19-2014, 02:04 PM
Ok, that worked better.. Even though this thing came in it's original box and paperwork, there is no instructions.. I got 20 on a working set, and almost 2 digits below 20 on the GE set.. Slightly lower..
