Pin problems give an hour glass shape. Adjust it to far & it
takes a barrel shape. Pin control is VR504. The cap that goes is C521 its off one end of the control. The manual says its either a 1mfd or 3.3mfd. There may also be a 1mfd tacked in in parralell with it prob under it. Use whatever it used. Focus is a tap marked F1, F2, F3. probable wont see any difference. Color problem check for bad solder on CRT board & dirty controls. Common conections are at socket itself & the 3 output transistors. That will keep you busy for now. 73 Zeno
