Old 01-16-2015, 02:11 AM
tvcollector's Avatar
I just ordered up some resistors.. I did find that 2.2meg resistor like you said, that's isolated near the .1 cap.. It measured around 3.0meg cold.. I also tested the Shunt regulator tube.. The tube chart shows a 6EA4.. There is a 6EJ4 in there.. On the tester it tests into the lower good side, and needle falls while in the test mode.. During life test it drops into the "?".. Now would this tube be causing the issue with the HV maxing out only at 22kv?
Old 01-16-2015, 07:56 AM
tube testers are not much good in sweep circuits, subbing for known good ones is the way to go. 3.0 is a little high, but i seriously doubt its the problem.
