Old 01-17-2015, 01:16 PM
I think he means mean the electrical bottom rather than physical (just to try and be more clear).
Old 01-17-2015, 01:26 PM
I will try to make this as simple as possible.
1) disconnect the wires from the bottom two taps on the fly, I presume they are marked 1 and 2
2) use a ohm meter read the resistance from the horz out plate cap wire to one of the terminals, note the resistance.
3) without moving from the horz out plate cap wire read the next terminal that was disconnected, note the resistance.
I will tell you what next after you do this and report back.
For everyone else talking about CRT pin voltages, remember per Timmy with the CRT anode lead disconnected the MAX voltage he could get with the HV pot maxed out was 22kv (IIRC) this is with the shunt tube connected.
Old 01-17-2015, 01:31 PM
ok will do that and then report back.
