Predicta Princess Networks
Just finished replacing paper and electro caps and some bad tubes in a princess, so far so good the picture is pretty nice and stable. Some horizontal linearity issue that won't clean up but otherwise OK.
I'd like to do some preventative maintenance if necessary. Are any of the networks more prone to failure than others? If so I'll replace those and leave the rest alone. Thanks! |
Nice!
Thanks for the pictures. |
Vertical feedback network- always. It's the smallest one next to the vertical output tube and easy to replicate.
Attached an operating photo
Align the horizontal oscillator according to the Sams or Philco instructions. That must be done regardless of any other troubles. It may make a big difference.
Is it me, or does it seem stretched vertically? I think the scan lines could be a little closer to each other, but other than that looks like a nice picture.
Evolution... |
It was, I had my source set to widescreen on accident; realized it after, and readjusted geometry
What you had before you corrected it was a rough simulation of the pre-war 441 line standard, before the FCC upped it to 525 lines. Had they stuck with 441 lines, the horizontal frequency would be about 13KHz, which people would hear worse than the 15.75KHz flyback whine.
