Old 01-29-2015, 11:45 AM
Right here on the FCC site, 3.5 kW ERP:
" Licensee: WOIO LICENSE SUBSIDIARY, LLC
Service Designation: DT Digital television station
Transmit Channel: 10 192 - 198 MHz Licensed
Virtual Channel: 19 (viewer sees this channel number)
Network affiliation: CBS
File No.: BLCDT-19991110AAR Facility ID number: 39746
CDBS Application ID No.: 428322
41° 23' 15.00" N Latitude Site in Canadian Border Zone
81° 41' 43.00" W Longitude (NAD 27)
Polarization: Circular (H = V)
Effective Radiated Power (ERP): 3.5 kW ERP
Antenna Height Above Average Terrain: 304. meters HAAT -- Calculate HAAT
Antenna Height Above Mean Sea Level: 567. meters AMSL
Antenna Height Above Ground Level: 293. meters AGL"
For another web study on reception in your area, try 'TV Fool", but I suspect the results will be about the same, however : http://www.tvfool.com/
I also gather , from reading through some of the applications on the "Application List" that the station is indeed, now running 9.5 kW ERP (and has for several years) under the authority of a Special Temporary Authority (STA).
This is all well and good, but I cannot understand most of the information. That FCC website was intended for broadcast engineers, not ordinary people like myself. All I know or care about at this point is that I do not get channel 19 (or channel eight) without cable.
I also tried the other site you mentioned (TVFool.com), but I cannot use that one either because I do not know the latitude and longitude of the area in which I live. Isn't the name of the village (or the city closest to it) enough? Why do I have to mess with those other numbers? If channel 19 is running at 95 kilowatts, I should be getting it here just using a piece of wire connected to where the antenna goes, and I wouldn't have to use the amplifier in my DTV indoor antenna.
Honestly, I wish the FCC had left the country's television system alone. The old NTSC analog system served us well for over 50 years; now we have a DTV system that doesn't work for many people without cable. I like my TV, don't especially care anymore how my favorite shows get here (meaning I don't care about the technical stuff behind DTV), and do not appreciate all this trouble I have to go to just to get the two channels I watch more than any other TV station in Cleveland.
Is there any chance the FCC will realize what a flop DTV is in most areas, and revert to the NTSC analog system? At least with that system there was a picture if your TV signal was weak; with digital, it is all or nothing. I like DTV from the standpoint of a clearer picture and more channels, but I can do without the reception problems.
Sheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeesh!!
Old 01-29-2015, 12:22 PM
The TV Fool website will take an address or even just a zip code... I tried it just using 44077 zip and it showed a *very* weak signal on channel 10 in the area. Address or coordinates should get results that are more specific to your location.
You must have miss-read the power that I stated; it is 9.5 kW ERP *not* 95!
Old 01-30-2015, 03:34 PM
Sorry, not gonna happen. The FCC wants much of the TV bands for other things anyway. Channels 52 to 82 became cell phone territory. And some for the police and fire depts, since 9-11. IIRC, channels 14 to around 16 in New York City are used for police and fire comms.
