Which one to choose, indeed? I don't have a manual, so without a schematic or part number to go by, I guess I'd have to pull the board and remove one to see exactly what's needed. Here's an animated GIF that I made to show the switch in action.
![]() Are all of these switches momentary contact? The mechanics of this one aren't clear to me. There must be a little spring or rubber somewhere to push it back out, but all of mine are completely loose. (To make that two-frame animation, I pulled it out and then pushed it in, where it remained.) Phil Nelson |
Just played with my set a bit more, and indeed some of the buttons *do* respond heavy pressure. Scan up/down can be forced to work sometimes, by pushing down hard on the tops of the buttons. I can't get the indicator button to do anything. If I push down hard on the band select button for a second or so and release it with a snap by sliding my finger off the front edge, I can nearly always get the band to change... YMMV! jr |
I was sent these from someone a long time ago for my KV-4000 series sets, but I never got around to installing them. I was told that these fit correctly, but have not personally verified that. They appear to have a piece of spring metal in them to pop them back out. Travel distance on the switch action is very minimal. . |
Has anyone tried poking around the stock at Digikey (or another supplier that provides spec sheets)? I found an SMT pushbutton to repair a Sennheiser wireless microphone there by matching up the dimensions I measured to the product spec sheets. Worked perfectly.
This all comes about because I use a Blonder-Tongue agile modulator to transmit TV indoors and I recently switched from using channel 3 or 4 to a higher VHF channel (12). Our house has some nasty RF interference sources and the higher VHF channels are less susceptible to such RFI. Phil Nelson |
So, I got the board loose.
![]() And the switches arrived (thanks, Jim!). ![]() The physical size looks close enough. ![]() But it looks like the old switches have two terminals, while the replacements have four. ![]() Not sure how to make these work. Am I missing something? Phil Nelson |
