Old 02-05-2015, 12:41 PM
12gn7 pins- 1 6.15 v 2 4.30 v 7 255 v 8 122 v 9 0 v
Old 02-05-2015, 12:43 PM
Does the contrast control work?
Old 02-05-2015, 12:44 PM
deleted I was wrong about a pin
Old 02-05-2015, 12:48 PM
those all look pretty good, if anything its driving too hard.
Old 02-05-2015, 12:51 PM
the contrast one way with the dark pic is one thing but the other way its so dark not worth trying to see.
Old 02-05-2015, 12:52 PM
power off, pin 1 to ground video out resistance reading? leave it connected for a min to stablize.
Old 02-05-2015, 12:58 PM
196.1 ohms pin 1 to ground after a moment connected.
Old 02-05-2015, 01:01 PM
zero ohms with tube out.
Old 02-05-2015, 01:05 PM
try a new blanker, and check the pin 7 (grid) of one of the diff amps (6Gu7) voltage. blank raster. check voltage with max and min CRT bias
Old 02-05-2015, 01:07 PM
dont know if this is of any help but when this set was always first turned on it was missing a color until about 30 seconds of being on so i thought it may have been one of the diff tubes taking longer to heat or conduct.
Old 02-05-2015, 01:10 PM
should have no effect.
Old 02-05-2015, 01:23 PM
6gu7 pin 7 bias down 1.325v bias up -3.53v no diff bright up or down.
Old 02-05-2015, 01:38 PM
if new video out and blanker tubes do not help. I would focus on the crt bias circuit.
the only thing I can see in there is a pot that goes to a .22 uf cap (chroma board up front on right viewed from back) and a 220ohm resistor.
outside of that I am stumped.
Old 02-05-2015, 01:45 PM
ok the 220ohm checks 194ohms so thats good and the .22 i checked with my mfd dvom checker and it came in lower then the cap i have that is good. i dont know if the little difference in capacitance will make a difference but i can change it.
Old 02-05-2015, 02:08 PM
i thought if you pull the blanker tube out the screen is supposed to black out. well it dont its all green and bright
