Well down here I have Cox Cable, and in one of my houses I have basic cable and I can get quite a number of stations direct over the cable connection to my older NTSC TV, and I have had no indication that this "basic" service is going away. Modern ATSC broadcasts over-the-air can be received from regular TV antennas, but you need an ATSC compatible TV to view them, or a converter box.
Cox is still putting QAM and analog stations out for direct connection, but not for much longer. As they drop channels from some packages, they add the basic analog channels to the digital-only lineup to keep the same number of stations in the package. Word is they will someday only have the "lighthouse" station on the analog side, along with their user-hookup channel. With my setup, I use an attic antenna for local viewing - PBS is awesome OTA, with no compression or artifact garbage. My only problem is my antenna is looking right into a two story building, so I get dropouts on one station. Cheers,
The HD picture is OK, using the RF out, but not as good as the OTA converter using the component jacks. |
When you scan the cable channels, on the ones that require the converter, they come up as a blank screen, such as the weather channel.
