Old 02-20-2015, 10:25 AM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
old_tv_nut nailed it in the above post:
Room light reflected from the CRT phosphor surface gets attenuated twice a much as light produced by the phosphor hence contrast enhancement. I suspect that there is also a trade off with tube life, as beam current might be turned up a bit to compensate for the brightness loss.
Another enhancement can be achieved by depositing an anti-reflection coating on the *front* surface of the CRT to reduce the approximately 4% reflection of room light from that surface... I don't recall seeing a consumer TV with CRT AR coating, but perhaps it was used on some high end models.
Very interesting, thank you for the information. So I guess this only helps in a bright lit room, and doesnt really change anything while watching the TV at night.
