Old 03-09-2015, 07:43 PM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
1976 Quasar console
About two years ago, I went on a little road trip (approx 500km round trip) to pick up this 76 Quasar console. Got it from an elderly couple that bought it new in early 77 for 861$ (they still had the receipt for it!). They told me that the TV had been in their basement since about 1991, and that they rarely used it since then. They where happy to see it go to a good home.
The reason, I bring this up now, is that I kept the TV in storage at my stepmother house since, but in a few weeks I bring it home with me, and I wanted to know more about it.
Obviously it's not as collectible as a real Motorola works in a drawer, but it's still early enough to be intersting (to me anyway ).
Please feel free to share your thought about this one!
Thanks!
Old 03-09-2015, 08:08 PM
Olorin67 Olorin67 is offline
My grandparents had the same set. My granpas brother was the local quasar dealer (marsden TV in Edgerton, WI) sadly its now a Subway...set was still going strong when i saw it 2 years ago.
Old 03-10-2015, 07:25 AM
Marco-nix's Avatar
Marco-nix Marco-nix is offline
I don't know much about Quasar...Mais tu as fait une bonne affaire ...If this set's working fine, it's a plus .
Old 03-10-2015, 02:12 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Quasar WID sets, Moto or Jap, are all showpieces in my opinion.
Old 03-10-2015, 02:54 PM
Findm-Keepm's Avatar
Followin' the Rules...
Thanks!
Um, rare in these parts! Your set is a "Super Module Chassis" set - 75% of the set's circuitry is on the SF-panel super module. The two Super Module chassis produced by Matsushita/Quasar were the TS-958 and TS-959.
I have the Technical Training data for your set - description, receiver functions, circuit descriptions, troubleshooting, and adjustments. Last two pages are the schematics for the 958 and 959 chassis. I may also have the Service manual for your set - I know I've got a lot of TS-95x-97x manuals.
Interesting chassis - 7 safety caps from the HOT collector to ground!
Cheers,
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 03-10-2015, 03:48 PM
Jon A.'s Avatar
Sounds like a fail safe design that would likely trip the breaker before the HV climbed high enough to do significant damage.
Old 03-10-2015, 06:17 PM
Hey , thanks buddy I really quite like it. It may not be a CC flat chassis, but it's the nicest console I have for sure.
I'd be really interested to know what its strengh and weakenesses are. Zeno?
Old 03-10-2015, 06:33 PM
Cheers,
Cheers,
Nice, This one needs a convergence adjustment, I suppose the procedure would be available in your litterature?
As for it being somewhat rare, I suppose that when Motorola sold to Matsushita, a lot of people in the US lost interest in the brand maybe?
7 safety cap? Hey that's 3 more than the CC, that's somehting!
Old 03-10-2015, 08:38 PM
Does this set use a delta gun CRT? I'd be interested in knowing who made the tube (the EIA number on the tube label should tell us).
Old 03-10-2015, 08:46 PM
Of course it does! V25VCZP22
Old 03-10-2015, 10:29 PM
This is an interesting set. I can appreciate the Matsushita attempt at the "works in a drawer" design. Seeing that you're in Canada, I'd be curious to know if this set was built at the Motorola/Quasar TV plant that was in Markham, Ontario. That plant opened in 1971 and they only built TV's for the Canadian market there. I don't know if Matsushita took over that plant right away or not when they completed the purchase of the consumer division in May of '74. Do you have the exact model and serial number from the back tag on this set?
Old 03-11-2015, 07:55 AM
Where I worked there were not many Motorola / Quasar sets. I
only remember putting a few hoz outputs in them. As a rule
anything Panasinic made was of good quality. Usually very easy
to fix & good runners.
Later in the '80's we did start selling Quasars as a lower priced set.
They were good except bad flybacks.
Old 03-11-2015, 08:33 AM
Nope - but there is a 2-page description of the convergence circuitry for both the delta and in-line CRTs. Understand that Quasar technical training covers unique circuitry that an experienced technician would need. They don't cover mundane, standard or non-unique adjustments such as convergence.
Your set has adjustments for all aspects - and the board is labeled as to what each pot/coil does. If the red/green or blue is out of convergence in an area of the CRT, just adjust that coil or pot. Out all over? Start with a static alignment with the neck magnets, and then perform a dynamic adustment using the pots/coils on the convergence board. The pots/coils are marked with their function, e.g. TOP BLU HORIZ or RIGHT R/G VERT.
Hope this helps - it would help to know if you've ever converged a TV.
Cheers,
Brian
Old 03-11-2015, 09:26 AM
The Quasar CRT's of that era were Sylvania. They seemed to be very long lived.
Old 03-11-2015, 09:30 AM
Marco-nix's Avatar
Dreamsbeard, check your private message
