Old 03-14-2015, 10:02 AM
sylvania sylvania is offline
I think i checked that but will look again, strange thing day before ok next day no raster.
Old 04-09-2015, 05:18 PM
sylvania deflection loss
I am giving you a update and hope i am replying correctly, This set is Sylvania 336m. I am supplying chassis with 117v line load is 2.56 amps.I have sound and a horizontal line across CRT, I checked the voltage on tube 12AU7 which if I read the print correctly is the oscillator section. Pin number 1 on the photofact shows 235v, on that pin I am reading 333v.Photofact shows pin number 6 at 135v, my reading on pin 6 is 113v. This is with line voltage at 117v which the photofact refers to when checking voltages. This chassis has been recapped and new electrolytics, I checked the electrolytics again and they show good. After I had recapped this set I had deflection and then is slowly went to horizontal line only. Thank you
