Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > General Off Topic Forums
Old 04-17-2015, 08:54 PM
Hi!!!
Im still a member here! Im going to try to be around here more lol. So, how's everyone been doing?
Old 04-17-2015, 10:11 PM
Long time no see, Mark.
I'm doing good, and still a bit of an otaku. I got me a classic car (there's a thread on it in the 'things with motors' section).
How has life been treating you lately?
Old 04-17-2015, 11:50 PM
WISCOJIM WISCOJIM is offline
Thought you fell off the face of the planet!
Welcome back.
Old 04-18-2015, 12:26 AM
Hey Tom and Jim, I kinda did fall off the face of the planet lol! Life has been rough but seems to be improving. A few more hurdles to jump and things might get back to somewhat normal
Old 04-18-2015, 01:47 AM
Dude111 Dude111 is offline
Analogue is Awesome
Hello buddy,im glad your ok
Old 04-18-2015, 05:26 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
So you makin it to ETF or what?
Old 04-18-2015, 06:19 AM
Looks like I am, Tim
Old 04-18-2015, 06:45 AM
Kamakiri's Avatar
Yesss!!!
Old 04-18-2015, 10:12 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
I recall seeing your thread about a 13" 1983 Mitsubishi. Late last year I got a similar 19" 1987 Electrohome-branded Mitsubishi, near mint, also with the blue-tinted CRT. I have the manual which calls the CRT "blue optic".
Old 04-23-2015, 06:53 PM
Yep, I still have the set but the vertical collapsed due to some bad caps. Sounds like you found a nice set. These aren't really valuable or anything but make good daily drivers and produce a nice picture.
Old 04-24-2015, 09:39 AM
Jon A.'s Avatar
I usually don't bother with sets that recent, but it's identical to one we had when I was a kid. It is the one I use most of all, which will likely change once my Chromacolor console gets new safety caps.
Old 04-26-2015, 01:37 AM
I usually don't either but sometimes make exceptions. I hope you get your Zenith going, they are great sets.
Old 04-26-2015, 08:38 AM
Jon A.'s Avatar
Same here. I also made an exception for a low-end 1988 Zenith console with the 9-516 main chassis which is in great shape and is spotless inside. The Chromacolor started for me as of last May, I just won't risk running it again until I get the new safety caps in (I still need a soldering station). Its CRT tests almost new, surprising to me even for a Chromacolor.
Old 04-26-2015, 02:41 PM
You don't need a whole station just pick up a ~20$ iron or gun from your local hardware store....It will probably even have as much solder as you need.
You do not need anything more than needle nose pliers to de-solder the old part from chassis style terminals, Just heat with one hand, and grab the end of the lead with the pliers in the other, and wiggle/unwrap/unloop, and once the lead is out heat and blow the solder out of the terminal....PCBs are even easier. I Have a couple of solder suckers, and honestly just don't bother using them except on multi-pin PCB parts.
Old 04-26-2015, 04:24 PM
Kamakiri's Avatar
Really? I use my solder sucker all the time. It's great for disconnecting wires or components where said component is wrapped in an eyelet type terminal. Hit it with the gun, suck the solder out.
Then when enough of the solder is out, wiggle the wire with small needlenose pliers or use a dental pick to unwind it while hitting it with as little heat as possible.
