Old 04-23-2015, 07:19 AM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Why a scope tube ? I would think retention would be
a problem with it.
The P1 green oscilloscope phosphor has about the same persistence as the white P4 television phosphor.
The ones that would be a problem would be the long persistence radar screens (P7), or the very short persistence types (P15, P16) used for flying spot scanners.
Old 04-23-2015, 09:56 AM
Notimetolooz's Avatar
Originally Posted by bhegges View Post
I am looking at building an all tube television and have some questions about the high voltage supply. In looking at some of the early designs a 1b3 diode was used in conjunction with a beam pentode oscillator. My understanding is that the beam pentode would feed a high frequency into the primary transformer winding and thus creating the high voltage secondary to feed the 1b3. I am thinking of using an oscilloscope tube and will probably need 2-6kv depending on the tube.
Bhegges, with only 4 posts here at this time one could think that you are new to this sort of things. I see now that you have already built a TV monitor using a 7JP4!
At any rate, I happened to find a article on an unusual HV supply. Only a little over 1 KV, useful for a scope CRT. It uses a series resonate L-C combination to generate about 500VAC, then uses a voltage doubler with a pair of 1B3's to produce about 1200 VDC.
Old 04-23-2015, 01:01 PM
bhegges bhegges is offline
Thanks everyone for your posts. I have been a passive member for quite some time and have always enjoyed seeing what everyone has been working on, my only posts were to share my tv project, a 7jp4 monitor. I have since sold it and now have started tinkering with electronics again and thought I might try my hand at another all tube crt. I would not have to go with a oscilloscope tube but I was looking for something that did not have too high of voltage needs. From the sounds of the replies the "brute force" is no better.
Thanks again,
