Old 05-11-2015, 07:50 PM
Originally Posted by stusnyder View Post
So then the center tap goes to the c19 12mfd lytic like the original trans did?
The center tap goes to the same place, the original transformer CT went.The set uses a B- line to provide bias for the audio output tube.
I have to look at the schematic again.
Old 05-12-2015, 03:45 AM
stusnyder's Avatar
Ok then there is 2 taps left, 5 volts and 6.3 volts. I assume the 5 volts are for the dial lights, and the 6.3 is for the filaments, correct?
