Old 05-17-2015, 01:41 AM
When i mentioned the thing that looked like a bulb socket i meant video not audio.
ok i looked at the video board and it doesn't really looked cooked , if anything the if section looks suspicious or might be dirt , perhaps since it is a vertical chassis that helps ?
been testing tubes and like someone else with a recent post on a ctc-9 there is a 6gh8 in the tuner instead of 6ea8 , the 3a3 is pretty weak , the 6bk4 even weaker , the fly doesn't look like it dripped or has any issues but would have to scrutinize it , the 3a3 socket is loose , looks like it was put in or put back in with hot glue .
forgive this question if its obvious but the hv anode lead does plug into the metal ring that the 3a3 socket is in right ?
mike
Old 05-17-2015, 08:24 AM
correct on the HV lead into the metal surround of the 3A3 socket.
Old 05-18-2015, 10:04 AM
that thing i said looks like a light socket is a light and socket , located near the on off volume , i didn't know it had a light.
Old 05-18-2015, 11:54 AM
the light is there to light up the controls under the door on the side.
