Old 06-28-2015, 04:42 PM
Transistor (but not portable) table radio fixed
A Hitachi table radio, solid state, uses transistors. Not a portable, so by some definitions it's not a "transistor". In any event, got it at a garage sale, as not working. It's a "hot chassis" design, the audio output transistor is a high voltage one, and the rest of the circuits are conventional low voltage transistor circuits. As seen in many such radios, it uses a dropping power resistor in series with the rectifier diode. In this radio, that power resistor went bad apparently on its own. Replaced it, radio now works. But I relocated this resistor away from the "high" side of the powerline, to the "low" side (connected directly to the radio's B- line and the power switch (which switches the low side of the line)). Keeps a hot resistor away from the filter cap.
And the radio doesn't seem to notice that its "ground" is bouncing at a complex 60Hz wave above external ground.
Old 06-28-2015, 06:44 PM
...And THIS is why Yr Humble Narrator NEVER wanted to learn to work on these things... NO WAY could I ever remember all the little "Ins & Outs" that can get one KILLED if you momentarily forget...
Old 06-28-2015, 07:41 PM
maxhifi's Avatar
maxhifi maxhifi is offline
That resistor sure looks out of place amongst all its Japanese neighbours! Cool radio, thanks for sharing.
Old 06-30-2015, 09:39 AM
According to the code date on the speakers, the radio is about a '70 model.
It seemed to be common practice,at the time to do it that way in the line operated radios. It could also be used on DC, unless it was a clock radio.
Old 06-30-2015, 11:51 AM
maxhifi's Avatar
I was referring to the specific
brown ceramic resistor he used, it looks very American made, and all other components are looking very japanese.
Old 06-30-2015, 12:04 PM
I was going to do a post reply instead of a quote.
I'm aware of what you were referring to!
Old 06-30-2015, 07:10 PM
radiodayz's Avatar
radiodayz radiodayz is offline
radiodayz
How does it play, WA2ISE? Big sound, but I'm assuming not stereo.
I have one of those around here, somewhere
Old 06-30-2015, 08:29 PM
No stereo, but it sounds good. Somewhat similar to a tube table radio.
Old 06-30-2015, 11:56 PM
maxhifi's Avatar
Haha sorry, that makes a bit more sense.
Old 07-01-2015, 09:34 AM
I understand the hi-voltage type output transistor is good for about 1.2 watts.
The impedence of the output transformer is about the same as one used with a 50C5.
Old 07-01-2015, 11:47 AM
... hi-voltage type output transistor is good for about 1.2 watts.
The "plate" voltage is a little lower, about 95V on the transistor. But an AA5 output transformer and speaker would load it nicely. I've actually done this and it worked well.
Old 07-02-2015, 10:05 AM
I love the sound on some of these old table radios.I have a Panasonic here from the 1970's and it sounds great.
Line powered.I'm surprised its not a GE.They love eliminating the copper power transformer way before copper prices skyrocketed.
this set could be a good candidate for converting it to FM and AM stereo since it already has the two speakers built in.Or probably not since its line powered.
Old 07-02-2015, 04:47 PM
The collector of the audio output transistor has curves that look a lot like a pentode
Of course the input side is way different, current vs voltage, but the output transformer won't know the difference. Also the transistor curves I grabbed are for one that isn't a high voltage one, but the high voltage ones are similar.
Thus this solid state radio would sound a little tubey.
Old 07-05-2015, 12:07 PM
Slightly out of thread, but related!
It amazes me how well the line operated, AM transistor table and clock radios worked with only four transistors, convertor, IF, driver amp and high voltage output transistor. They seemed to work as well as an AA5.
It seemed that, the battery operated radios needed six of more transistors. I'm not referring to the audio output, but the receiving qualities.
