Old 07-02-2015, 08:19 AM
ZackN920's Avatar
ZackN920 ZackN920 is offline
1959 Zenith D3004W-Space Commander 300
Hey y'all, where could I find a schematic for this set? It has the "Super H20 Chassis" in it. I dont know at the moment if there's a more specific chassis identification code or not, just let me know if there is and I'll see about pulling the tv out of the corner to have a look.
General gist is that the set seems to be developing issues, and I'd like to turn it into a daily driver. I also got to get it apart sometime to give the flyback some attention. Last time I took a peak at it, it looked like all the black coating fell off and was laying in a pile of chipped off pieces. (Mabey the reason it sounds like a burning cigarette with the back off)
I've got more I could add but I'm out of time
Old 07-02-2015, 09:11 AM
WISCOJIM WISCOJIM is online now
"where could I find a schematic for this set?"
In Sams Photofact 467-2.
Old 07-02-2015, 10:04 AM
Adam's Avatar
Adam Adam is offline
That's the 16D21 chassis, also in the Zenith manual TV-23. If you can't find a copy, I can scan the schematic either out of the sams or the zenith manual.
Old 07-02-2015, 12:43 PM
Sounds to me as if the CRT is shot. The black coating flaking off the bell of the tube (the aquadag) acts as a huge capacitor in the high voltage system. Without it, the CRT cannot get 2nd anode voltage, which will of course kill the raster.
I'm not sure where the sound you're hearing is coming from, but it seems to me that the missing aquadag on the bell of the CRT may have a lot to do with it. In any event, the tube is now little more than a glass jug and must be replaced.
Old 07-02-2015, 03:34 PM
Lost dag on the exterior of the CRT can easily be washed off and re-applied... The CRT may be ok... more testing is needed before counting the CRT as "shot".
The dag is used as a filter capacitor for the HV supply, but its absence will usually just cause more AC "ripple" on the HV... HV is likely still present, and likely arcing, perhaps to the flakey dag or from the flakey dag to the chassis ground strap.
But it really sounds as if the flyback not the CRT is the source of the black flakes?
Old 07-02-2015, 08:39 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
I also have a h20 zenith space command. I'll look and see if I have the schemstic for it.
Old 07-02-2015, 11:32 PM
ZackN920's Avatar
Thanks for the info guy's.
Adam, thanks for the offer. I'll have to take you up on it if I dont find anything. I'd like to see one soon, to at least find out what the electrolytics in this set are, to make an order if I have to.
My picture tube is fine. (look at my avatar pic) It hasn't been tested, but it gives a great picture, and is way too bright if I crank the brightness up. Nothing is or has been flaking off of it. If it was, the chassis would be dirty with it.
No, all that crap that I was talking about is in the high voltage cage. There still is a little bit on the hv trans, but most is off. It's also hard to get into the hv cage on this chassis, so i've never gotten a good look at it.
Hey Radiotronman-Nice set! Looks exactly like mine other than the case. Does it have dual speakers?
Old 07-03-2015, 12:02 AM
Adam's Avatar
40uF-400V
80uF-400V
100uF-50V
10uF-400V
4uF-350V
20uF-25V
Old 07-03-2015, 12:06 AM
ZackN920's Avatar
^Oh, wow... you got that right off hand?
Cool, I'll have to check my stash now, and make an order.
Old 07-03-2015, 11:45 PM
ZackN920's Avatar
Well, I found some pics of this set, back when I had it in storage and right after I got it in the house. The Chassis number is 16D21Q. Also have a question for those who have taken one of these apart. Does the CRT stay in the cabinet or is it bolted to the chassis?
Here's a few pic's!
Old 07-03-2015, 11:52 PM
rca2000's Avatar
rca2000 rca2000 is offline
I HAD a set one year newer than this one (16E21Q.).(cabinet got RUINED ...by water ...in the old garage..) Still have chassis and I think tuner SURE I have SC chassis. it DID somewhat work...last time lit off. Tube DID come off with chassis IIRC.
Old 07-03-2015, 11:58 PM
ZackN920's Avatar
That SUCKS^^^ Mine's got damage on one side as well. Not water though, I think it saw the sun for years. Good to know about the CRT. I don't have to disconnect anything from it.
Old 07-04-2015, 12:06 AM
rca2000's Avatar
Mine was MUCH worse. I would NOT have scrapped it if it had looke dlike yours. but instead...the back cover had DISINTEGRATED...one whole SIDE was rotted away and the bottom was crumbling...
Tube on mne was GREAT in 98 or so last time i had it lit.
Almost sure nothing needed to be unhooked to remove chassis/tube assy frm mine.
Old 07-04-2015, 02:39 PM
ZackN920's Avatar
^WOW, how high had water gotten?! Sounds like the chassis would've been wet aswell. That's pretty impressive for it to still work as well, if it got wet.
It's great to know that I don't have to pull anything apart right away. Hopefully I can get the whole thing in the basement to my bench all together. I'm sure glad I don't have to take it up and down the stairs several times to check my progress when I recap and make a few modification's. I plan on keeping the case up on the 2nd floor. It was a pain getting up their. Would have been better if we used a dolly....
Old 07-04-2015, 06:12 PM
holmesuser01's Avatar
I have this set as a tabletop version. Before it was given to me, it had a metal base that swivled under it. Mine is untouched since 1974, and has the oem remote.
Bruce
