Admiral C322C2 Regent (Restoring) RCA CTC-7 Pensbury (Restored) RCA CTC-5 Westcott (Restored) CRA CTC--4 Director 21 (Restoring) |
two 1600 ohm in p should be 800 ohm total look at the schematic, it drops the 382v to 270v the 382v is at the output of the filter choke and 80uf filter cap.
from there you should see two 1600 ohm resistors, prob large WW types. |
They are R104 and R105 in the factory schematic, each rated at 10 watts:
![]() Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
One read 809 ohms the other red 810 ohms.
well they are connected in p so will read the same value.
That clears the resistors as an issue. Next if you do not have a cap tester to check 50 uf for leakage, you will need to disconnect it, temp tack in a new one and power up to see if that brings the 270v back up. C104-b on the RCA schmatic (not shown on the clip from Phil) look for the 50uf section of C104 and check for continuity of the connection to make sure you are disconnecting the correct tab of the can. The schematic show C104-A, this is NOT the one. you are looking for the SQUARE mark on C104 not the 1/2 circle. Last edited by DaveWM; 07-09-2015 at 02:20 PM. |
disconnect only C104B the Square, connect the disconnected wire to a pos of a 50uf cap neg to ground.
I'd connect the ground to the ground pin on the filter cap? Please bear with my pure stupidity here please.
