I agree it's not a dedicated sweep gen - I used plenty of them in the Navy - HP, Century and Wavetek, but it's the best-all-around for TV use. As to the scope and X-Y mode, I dunno - the VA62 was paired with the 60MHz SC61, but a common 20MHz scope does fine. Trying to resolve on a cheapo 5MHz scope will drive you nuts. And what do you use for calibrated markers? VA48 can be had for less than 50 bucks, and will do a lot more for a tech than a sweep gen. I have the HP 8601 and a Wavetek 185, but would never reach for them in servicing a set - see my prior comments on IF alignment necessity. In 25+ years of fixing sets, I've never had a set that needed alignment. 1 exception - APC alignment, easy with the VA48. Not saying that others haven't had such luck, but too many folks (newbies?) see a problem, and without troubleshooting, opt to align, when the problem is an open peaking coil, a shady cap, a missing bias voltage, AGC gone wonky, or a defective IF amp tube or transistor. Blade track an ARC-51, align a APX-72 lid with a perfect bell curve, or align a 1030MHz preselector in a UPM-137, well, yes-I'd grab a sweep gen first. Of course, offer me an HP 8656B, and I'd probably sing it's praise - loved those sig gens I used in the Navy!
http://www.videokarma.org/showthread.php?t=259995 I don't have the equipment or skills to align in the conventional way. Maybe this could be used instead? I do have a 30MHz B&K 1474 scope which I've used to observe lots of TV signals. That scope supports X-Y mode. Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
