Old 08-04-2015, 09:47 AM
Hoodcom's Avatar
Hoodcom Hoodcom is offline
AK Subscriber
The degauser "DGS" on most NAP sets works at turn off
not turn on like most. Also this one uses a triac instead of
the usual relay so no click. If the DGS were not working
you would soon have totally messed up purity.
The power stops flowing to the thermistor when I power the set off. I don't see any power going to the coil upon power on or off either.
20 Inchers should normally look a little better, but not sure If you'll get it all better
than that.... If you have not done it before, be ready to do it several times to get it
right.....
At least it'll be a learning experience.
Before you begin, look at those parts and see if the white glue has not dried
and cracked and let those parts move a little.... You may just be able to move them
back and reglue and be done with it....
No white glue, but it appears to be like a brownsish type of adhesive on the three wedges around between the yoke and the CRT tube. The yoke is fastened by a clamp.
Moving the yoke is pretty much for purity, If you don't have a purity problem, then
best leave it alone....
That's what I thought too, but it claims you do it for the edge convergence.
On the other hand, I did a Sanyo DS25250 or something like that, 25" it was horrible
when I got it, the glue cracked, and the entire assembly moved, no clamp.
When I was done, it was almost perfect, I thought my sister was going to take it
back, but she didn't we use it now full time, and it's really got a great picture...
Awesome, I would simply like to get this Magnavox in that same condition.
Doing it is a little different than the delta gun set, but you can definitely get these
tubes much better looking....
Ah, so that's what this type is, a delta gun?
Don't forget some of these tubes have little magnets actually taped to the tubes to
do fine conv. touchup.... Not sure if you have to remove them or not....
Good luck, please post your results.... !
Hmm, this one doesn't seem to have any. However, could I add any to help fine tune on this set?
Thanks, I likely will!
I wish I would have documented that Sanyo, it's really a great performer and looks
great now..... Although not perfect in one corner, not that it matters it's really on the
edge....
Documentation does help, so I hope this one can be one to be helpful.
