Old 08-10-2015, 08:12 AM
pac.attack76's Avatar
Stuck in the past
Ok, guys, looking at the board where the words "live" and "isolated" read upright, the pins are like this:
. . . With the cap out to the left. Now, going from left to right, left to right, i got: -.033, -14.06, -.003, -1.26, .000
Not sure if i did this right. Red on right side of cap since the other side has a plus mark. Set to VDC.
Old 08-13-2015, 07:46 AM
Stuck in the past
Did i do this right. If not, i can hit it again.
Old 08-13-2015, 09:55 AM
rca2000's Avatar
rca2000 rca2000 is offline
You did it BACKWARDS. Put the black probe lea don the hot ground. Use ther red or positive one---for all of the other readings.
BUT...i did NOT see any 171 volts on ANY pins of that chip. Are you SURE_-you got all of the pins? 2 of them are scattered from the otherrs--remember. if you did NOT...then check those 2 large resistoirs beside of that chip...and see if they are OPEN. They likely read LESS than one ohm. If OPEN--that ahip IS shorted.
Old 08-13-2015, 02:08 PM
Stuck in the past
Ok, i figured as much. I'll hit it again tonight or no later than tomorrow. I'll need to get this part, whatever it ends up being, ordered so i can get it in soon.
Old 08-13-2015, 02:42 PM
Stuck in the past
Yeah, i missed two pins. Layout is actually:
Now from left to right with black on cap neg. i get:
169.8, 13.73, .017,
.000, 1.309, .004,
.000
Note these are taken with board out of set but still plugged to ac.
Old 08-13-2015, 05:39 PM
rca2000's Avatar
At this point...I would re-check ALL diodes and any transistors near that IC..on th HOT side of it (within that white drawn area surrounding HALF of the transformer and optocoupler.) be SURE to check any diodes and make sure none are shorted.
If you do NOT find anthing...that i would order than IC and the optocoupler--as a "just in case". Your voltages indicate the IC is NOT shorted and is getting full voltage from the big cap and it ALSO looks to be geting its "start voltage" too. I would gues it is just bad.
Old 08-15-2015, 06:20 PM
Stuck in the past
I have a guy in the area that looked at the board the other day and he thinks the optocoupler is bad. Probably $1 or $2. Hes wondering what the readings should be if it were good. Getting voltages on the large cap and STK.
