Old 08-17-2015, 10:08 PM
roundscreen roundscreen is offline
Have you checked the mica caps on the horz and sync boards? They can go bad. Also, Some of them look like mica's, But are paper caps. I have had to replaced them in the ctc 5 with the same problem. Wonky horz hold.
Old 08-18-2015, 06:32 AM
Here is a picture of a mica cap. It is the red thing with the color dots on it. Sorry it is hard to see. Had to shove the camera in the set to get closer to the board. The set in the picture is a ctc 7c.
Old 08-18-2015, 02:43 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
Says its a 680 uf with no voltage rating?
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
Old 08-18-2015, 05:34 PM
SwizzyMan's Avatar
OK just going to replace ALL ceramic caps on the horiz sync board just for good measure.
Old 08-18-2015, 07:22 PM
I looked at the sams and saw the same thing. No voltage rating. Put in a modern 1000 volt cap and see what it does. Take your volt meter and measure the dc voltage with the new cap in place. See what you got. Also a mica cap and ceramic caps are two different animals. You want to check the mica caps and ones that look like them.
Old 08-18-2015, 07:26 PM
SwizzyMan's Avatar
Will do thanks a BUNCH! Will stop by the store tomorrow and pick those up and report back with my findings.
Old 08-18-2015, 09:18 PM
Shouldn't that be 680pF not 680uF? Any non-lytic should not be more than .68uF in an RCA product of that vintage.
Old 08-19-2015, 05:47 AM
SwizzyMan's Avatar
Yes they are all in PF not uf
Old 08-19-2015, 05:22 PM
SwizzyMan's Avatar
I am so happy I finally fixed my horizontal hold problem! Replaced all but one of the ceramic/mica capacitors and my hold is now stable. Thanks a whole bunch to roundscreen who suggested I replace the ceramics and the micas. Now back to my color problem. What do you guys suggest?
Old 08-19-2015, 06:15 PM
SwizzyMan's Avatar
OK adjusted L704 and was able to fix the rolling rainbow bars I now have color but the colors on the color bar pattern are all wrong. I tried messing with the tint but it did not give me the correct colors but did change the colors.
Old 08-19-2015, 06:53 PM
Could you post a picture of the color bars as they are now?
Old 08-19-2015, 07:00 PM
SwizzyMan's Avatar
Here is what it looks like now note the blue on the far right is very dark because the blue knob wasnt turned up all the way
Old 08-19-2015, 07:02 PM
done
Old 08-19-2015, 07:04 PM
SwizzyMan's Avatar
Black and white looks fine. I did accidentally adjust T704 thinking it was L704 at one point.
Old 08-19-2015, 07:11 PM
Your picture on that set looks really good. Nice job.. How is the picture on a ota converter?
