Old 08-30-2015, 01:55 PM
Anyone familiar with servo motors, solenoids and relays found in color tuners.
Moved this to color TV thread.
Old 08-30-2015, 05:29 PM
What era of set are you interested in?
Most sets made between 1955 and 1975 used a standard tuner with a modified phono motor to drive the shaft. The motor would push it's shaft forward and spin when powered to engage a down gear system that connected to the tuner shaft. There would be a star wheel on the tuner shaft and the wheel usually would have tabs on it's petals. The tabs depending on how they were set would contact a switch when on a channel detent. That switch would turn the motor off. Individual tabs could be set to not turn the motor so the tuner would skip unused channels...
Most sets with mechanical tuning used sonic remotes, with a few rare exceptions.
As for varactor and newer sets, as well as a few oddball mechanisms I'll let others chime in.
Old 08-31-2015, 09:14 PM
Findm-Keepm's Avatar
Followin' the Rules...
Tom, you must be a technical writer - that is an outstanding explanation, a very compendious paragraph!
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 08-31-2015, 11:33 PM
Cheers,
Thanks for the compliment! It's good mostly because I lost the first writing and had to start over....I have not yet begun a career, but I did have some technical writing course work some years back as part of my degree.
