Old 10-01-2015, 11:21 AM
Arcanine's Avatar
Arcanine Arcanine is offline
Originally Posted by Zenith26kc20 View Post
I replaced both integrators in my 25MC33. They caused the trouble you have. They are hidden near the vertical output transformer. My service manual is not here but I can look at it this weekend and get the values. They look like three leaded brown ceramic disc capacitors with yellow writing on them.
Check the plate resistor on the burst tube. The tubes can short and draw too much current and burn the resistor.
If you can get a service manual, there are two test points that you have to ground to turn on (defeat the color killer) the color circuit and the other defeats the color afc so the oscillator can free run. If you don't get floating color bars after grounding the test points I would replace the color crystal first. You may need to go thru a couple if the first one doesn't help.
Don't turn any coils unless absolutely necessary. They can get fragile with age.
Yeah I'm worried those are shot in mine, and I'm not sure how to build a new one to replace them. That's why I am watching his posts like a hawk. His set suffers the same issues as mine. He's indirectly printing me a road map what to tackle next.
