Old 11-07-2015, 06:03 PM
Brought them in the garage and tested the CRTs. The one in the GE tests excellent.
The CRT in the Dumont had an unplugged brightener on it. It started off bad, but with brightener level heater voltage got almost as good as the CRT in the GE...Dropping back to 6.3V after that got me the bottom edge of the good range.
Better pictures:
Tom Albrecht repaired one of those tuning shafts on his Crosley 9-407 (with the same Dumont chassis) a while back; you should be able to find his discussion of it. He had an excellent description of the problem and his work.
Good to know. VK's search function did not find it. Got a link?
Old 11-07-2015, 06:12 PM
What HFH store was it? The one on 104th and Burleigh?
The parking lot is awful small too! That store is very poorly organized, but at least you got something, that was worth the trip.
Old 11-07-2015, 06:22 PM
Don't crank that inductuner mechanism too hard until you have a chance to pull the chassis and give it a careful cleaning & inspection. This article has some photos of the tuner:
http://antiqueradio.org/DuMontRA-103Television.htm
I've heard of those tuners having a broken ceramic shaft. My RA-113 even had a broken gear in the mechanism. Those things might have happened when lubricant dried up and turned hard, and then someone forced the tuner.
Phil Nelson
Phil's Old Radios
Old 11-07-2015, 06:30 PM
Phil Nelson
Phil's Old Radios
I was gentle with it when turning it. If the user shaft was properly pushed in to place it felt as though it was turning other gears (silent mild resistance to rotation)....My hunch is that the tuner shaft is free albeit a pinch gummy, and all that is wrong is the user control shaft. In any event I don't intend to mess with it until I pull the chassis and can see what exactly is going on.
114th & Burleigh. The lot is small, but finding it after dark was hard enough to distract me from it.
Old 11-07-2015, 07:07 PM
I usually tried to stop there, when I'm in town but haven't found anything, so I didn't bother the last few times.
BTW, I hope to see you at the Landmark tommorow. I have the items loaded in my car, that you were interested in.
