My TV transmitter rack is plugged into an isolation transformer to kill a ground loop problem. One of my agile modulators despite that seems to like to swamp it's inputs out with hum at random though.
Another possibility is bad filter caps in the BT power supply.
In CATV service, these units operated 24/7, for years at a stretch, while packed into hot, crowded equipment racks. Perfect conditions for degrading the electrolytics in the PSU. |
Gregb |
OK, here are my findings with the bars on my TV's. Like I said I have recapped the BT modulator, that greatly improved the picture quality but also made the bars that much more visible. I have tried an isolation transformer, I have tried reversing plugs to try and get the commons all in the same place. I went into my panel where the cable feed comes in and tried without the ground connection and with the ground connection, no difference.
I found the problem by accident, I was working on trying different things and I moved the antenna and when I tried the set out I noticed the bars were not as noticeable. So I moved the antenna about 10 feet away from the BT, no more bars, perfect picture. Must be some kind of signal feedback with the antenna to close. Hope this works for anyone else having the same issue. Gregb Last edited by Gregb; 11-28-2015 at 09:02 PM. |
Did you move your transmitting antenna ten feet away, or the antenna connected to the TV set?
Gregb |
OK, thank you for this tip! I have seen the hum bars with a modulator here, too, so I will try this trick.
