Old 11-20-2015, 08:50 PM
Arcanine's Avatar
Arcanine Arcanine is offline
It is running slightly less than 200mA, on the 6LQ6. I have not checked parts in the horizontal osc/drive system (aside from the 6CG7 which is quite strong) or the waveform. Don't know if my boost rect is silicon or what, I'd have to check that.....If it ain't then the only way I can put a 'fast' diode in is if I happen to have one in the parts I've scrapped off BPC sets. I don't stock any other new diodes that can take the voltage and current, and I don't buy parts online. I don't have any SS 3A3 or 2AV2 substitutes either.
AC at the outlet the set plugs into here with it on is 117VAC. I will look for a high line voltage primary tap on the transformer.
My thoughts on adding a fan are that one should add a Heppa filter in the air intake to limit dust intake.
The flyback was getting really really hot even before he changed out the diodes. Even before the set was working even half way correct, the fly kept getting really hot on me.
Old 11-22-2015, 03:22 PM
Fant's Avatar
Fant Fant is offline
I use thermal joint compound or grease to aid in heat transfer from transformer frame to TV chassis.
"You want it WHEN?"
