Old 11-26-2015, 04:24 PM
Dubis7's Avatar
Dubis7 Dubis7 is offline
Alchemizes cash to tubes
RCA RP 205 changer
Does anyone have the photofact for this model? I'd like to tear down and regrease mine, but I'd prefer to have reference diagram.
To keep your tubes running smoothly, make sure to dust underneath the glass as well.
Old 11-26-2015, 08:15 PM
Banned
I don't have a service manual but I do know what unit you are referring to, it is a mid 1950s vintage self-contained 45-rpm only changer with a single 25L6 powered amplifier built in, I actually have an owners manual from a similar model and that has some service information included with it but no a complete service manual.
I actually serviced one of these (a different model but a similar unit) and there really isn't much you need to tear apart to relube and get it going, mainly just the cam gear and the assembly that fits ontop of the cam gear, If I remember right.
Old 11-26-2015, 08:55 PM
Dubis7's Avatar
Mine is a 4 speed changer, and it's just the changer mech. It's part of a 7-ES-6J player with a 3 tube amp (35Z5, 50L6, and 12SQ7).
Admittedly, mine is working correctly at the moment. I've had periodic speed issues, but deep cleaning the motor bearings in lighter fluid and adding sewing machine oil to them seems to have taken care of the issue for now. However, I never gave it a full regrease, and I figure it'll eventually slow down again because of the old grease.
Old 11-26-2015, 10:45 PM
Findm-Keepm's Avatar
Followin' the Rules...
Lemme check - I have a bunch of service lit for RCA changers.
Kudos for listing the model and not the year....
Brian
USN RET 22YRS (Avionics/Cal)
Old 11-27-2015, 03:02 PM
Olorin67 Olorin67 is offline
i think i have the rp205 manual. i can check when i get home. Might have to see if i can get my scanner working also.
Old 11-27-2015, 04:27 PM
Best I could find in my stash was the RP-205 supplement to 1956-10. That is the manual you are looking for - RCA 1956-10, RP-205 Record Changer Service Data.
My supplement shows only changed part numbers for a few parts, but lists all the suffixed model changers.
Cheers,
Brian
Old 11-28-2015, 10:15 AM
Dubis7's Avatar
I found it on Sams for 15 dollars. The design isn't identical to mine, looks like an earlier revision, but I imagine the mechanism is the same.
https://www.samswebsite.com/en/photo...ndex/id/143440
Old 11-30-2015, 09:45 PM
OvenMaster's Avatar
DTV blows
Was that changer maybe built under license from Voice of Music, or did RCA rebadge it? Personally I don't know of any other OEM but V-M who had those two prominent 10" and 12" disc sensors near the tone arm pivot.
http://www.thevoiceofmusic.com/popup....jpg&TITLE=950
http://www.thevoiceofmusic.com/popup....jpg&TITLE=955
Tom
Old 12-01-2015, 07:45 AM
Dubis7's Avatar
No, it's RCA specific. I found that out when I tried to order parts for it from Gary and asking for the VM RP 205 came up with a single speed kiddie player with no changer.
Old 12-01-2015, 12:34 PM
RCA did license the design from VM, but they changed a lot of things, few parts interchange. Admiral also had the same type of 10" and 12" sensors after 1954, I think they got sued for infringement. The later BSR mini changer had similar sensors.
Old 12-01-2015, 12:35 PM
RCA did rebadge VM changers in the early 50's before taking manufacture in house.
Old 12-01-2015, 06:38 PM
OvenMaster's Avatar
DTV blows
Wow. Never knew this. Just thought it was a possibility, and maybe save you some effort, Dubis.
Tom
Old 12-05-2015, 09:57 PM
Dubis7's Avatar
Maybe. I found the photofact under RCA, though.
