Often if one end of the spring can be removed one can edit down the spring by chopping a few coils off, bending the end to hook on the old connection point, testing tracking force and repeating if necessary.
By the looks of that clip that's attaching the spring though it looks like it wasn't meant to be adjusted, and I've seen some of those types of clips before, they're not meant to be removed and reintalled again because when you remove it, you have to replace it with a new one or just not remove the original, which is why I said it probably wasn't meant to be removed or readjusted.
I purchased a new cartridge and shortened the spring a bit and now it seems to be working much better! Again, thanks for the help.
I have another problem though... I have a flip cartridge (81T) and both sides say "LP". Both side say "LP" on my 89TX as well. Both needles look the same to me. The cartridges only mount one way. Can anyone confirm which side is for 78s and which is for LPs? |
