Old 12-14-2015, 09:40 PM
If the yoke unplugs from the chassis, then is it perfectly safe to unplug (also safe if soldered on, but more of a pain to remove and reconnect properly).....Just don't power it up with the yoke disconnected....Pull the HO tube cap if it's series string heaters (if parallel pull the H and V output tubes) and you need to run it without the yoke.
If you have a test CRT and a spare yoke it will probably work safely with any similar era yoke.
