Resistor or capacitor?
Pretty sure this is a funky style cap, but whatever it is, it's not a good capacitor OR a resistor.
Any clue on the value as well? Thanks
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
Probably a resistor..... Take at least one leg out of the circuit and see what the meter
tells you it is...... .
Already did that. It's open.....AND doesn't read as anything on my capacitance tester.
The value (502) suggests it's a capacitor, perhaps 5000pf, as 5000 is not a standard RETMA/EIA value resistor in that size. What's the set? Sams/Rider?
This is that same Admiral 20X12 that I've been working on. I'm trying to trace down an AGC issue, and I can't decide what this part is. Sams 100 folder 1, coming off pin 6 of V7. And it's definitely not the .01 cap.
Was gonna put it in the thread for the set, but I figured this was a quick answer for somebody.
Pin 6 is the screen and has B+ on it. So there should be one end of R32(5.6K) soldered from pin 6 and it feeds B+ through L14, L13 to the plate(pin 5). Possibly someone replaced the original R32 with that thing? R32 on my 20Z1 is also funky looking, but not exactly the same as yours.
yes thats a resistor seen them befor. look at the opposite side it may show the value.
I agree with Findm-Keepm, it looks like a 5000pf cap to me as well. I have seen lots of them before in different sets. Maybe some past tech changed it for some reason. What does the other end of it attached to?
Gregb |
FWIW this is V7 in my 20Z1...
I would check the schematic for sure because I have one of those and it shows on one side 5 meg ohm on it.
To me it looks like some tech replaced one of your video peaking coils with an adjustable? Do the solder connections I've circled look factory to you guys?
Well, have you checked for B+ on pin 6 (screen grid) of V7? If there's none, is there B+ on the other end of where the mystery component connects? If so, what does that tell you?
May be for the day, a criticle duty resistor....
Definitely a resistor. Much improved
![]() I'll continue about it in this thread: http://www.videokarma.org/showthread.php?t=265850 Somebody done definitely screwed around with this set....
That was my best guess. Do I win a prize? ;-)
