Old 12-19-2015, 11:30 AM
Originally Posted by wa2ise View Post
One last tweak: Had to tune the modulator's 4.5MHz FM sound subcarrier frequency. It was a little off, which caused visible beats with the chroma subcarrier (I made it switchable: color or B&W). Now it works well. Looks like the best improvemsnts came from using a dedicated voltage regulator, tuning the subcarrier, using well shielded audio and video lines.
Can you elaborate on how you made it switchable: color or B&W?
Old 12-19-2015, 12:32 PM
He probably mixes the two S-video lines and has a switch in the color line to disconnect it....Many here have been getting pure monochrome by disconnecting the chroma line on S-video connectors.
Old 12-19-2015, 01:52 PM
That's essentially it, though here I created a low pass luma filter, a bandpass chroma filter and merged these to create a composite video signal that would look good on older color TV sets (the one that use a notch filter). I switch that and an unfiltered luma only signal.
Old 12-19-2015, 02:38 PM
Thanks for sharing this. And what type of rf modulator are you using that runs on 5 volts?
Old 12-19-2015, 03:31 PM
Findm-Keepm's Avatar
Followin' the Rules...
I dunno, so I asked Google:
http://www.talonix.com/shop/item.aspx?itemid=10044
2 bucks.
Brian
USN RET 22YRS (Avionics/Cal)
Old 12-19-2015, 05:16 PM
Hey, those are cute.
Old 12-19-2015, 06:30 PM
Naw, these are cute - and small - looks to be matchbox sized, and also 2 bux.
http://www.talonix.com/shop/item.aspx?itemid=10045
Brian
