Old 12-24-2015, 06:10 PM
You can use a #47 or #44, but the projected image will be smeared/blurry.
The required bulb has the filament configured to provide a point source of light.
It has a designation number consisting of four digits, something like 1829 (that's not the number, but something similar) and danged if I can remember it. Somebody on here surely remembers it.
Old 12-26-2015, 08:00 AM
Yes- the correct miniature lamp you need is a #239. This is the right bulb for ALL Zenith channel window applications. Buying NOS from ebay is about your only source to find them now.
Old 12-26-2015, 09:16 AM
Yes- the correct miniature lamp you need is a #39. This is the right bulb for ALL Zenith channel window applications. Buying NOS from ebay is about your only source to find them now.
The numbers, I remember are #239 and #240.
The 1956 model B/W sets, used a PR12 flashlite bulb.
Old 12-26-2015, 09:23 AM
Dieseljeep is exactly right. I meant to say "239" instead of "39" and corrected it. Either 239 or 240 are the correct bulbs!
Old 12-26-2015, 09:40 AM
Replacing indicator lamps in all sets, was always a big PITA. Seems like every set used a different lamp, ever different years of the same make.
If you didn't have the proper lamp, many times, it meant a return call or a trip to the supply house.
Old 12-26-2015, 10:35 AM
239. Ya that sounds right. So it was a 3-digit number, not 4 digits. Senior moment.
Old 12-26-2015, 11:34 AM
They were changing some of the numbers, such as 1847 vs 47. They claimed the 1847 was a longer life lamp. That's all I bought, towards the end.
How about, the real tiny, two pin lamps that RCA used in some of the XL100's.
It was nice when the customer would tell you up front, that the channel indicator was out, so you would come prepared.
Old 12-26-2015, 01:25 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
A google search shows several sources. Here's one: http://www.bulbtown.com/239_MINIATUR...BASE_p/239.htm
-Steve D.
