I really like that slant design, sets it apart from all the boxy portables that were out there in the 50's. It seems philco had a habit of choosing design over ease of servicing, thanks for sharing though!
I've never had the misfortune of working on one of those lousy RCAs so I can't compare.
I finished the recap, and selenium replacement...Save for the 100uF 450V section of the top can...Which tested good, and I don't have a replacement for. It works well, but I can tell from how much sharper, brighter, and more contrasty my 8" test CRT is that the original 17" jug in it is far from great....I may eventually add a brightener if I put this in regular service. ![]() ![]() ![]() ![]() One odd thing is that the Horiz AFC diodes are mounted on their own terminal strip despite having a perfectly good place to attach to the board....It's like a previous run had a bad batch of diodes and they expected these to fail too. ![]() To give an idea of the compactness here is a shot of it on a 17" RCA....The only thing I have with the same CRT that might be more compact is a Setchell Carlson portable.
