The longest I ran it was for about 4-5 mins this was when I could get a nice bright raster. I noticed an 80uf sprague atom was tacked on to the existing 80uf section in the filter capacitor. That isn't good since the original capacitor could mess with the tacked on 80uf. I also noticed that another filter cap was leaking a bit of PCB infused gunk out of one section. This set needs a nice full recap and that is what I plan on doing before I power up the set again. Will create a separate thread about this set soon. At least I know my 21ax is good!
Admiral C322C2 Regent (Restoring) RCA CTC-7 Pensbury (Restored) RCA CTC-5 Westcott (Restored) CRA CTC--4 Director 21 (Restoring) |
Probably not related, but when I first brought home my ctc-5 it worked okay. The next day I couldn't get a raster. It took me a long (really long) time to figure out what had happened. There is a shield attached to the underside of the chassis and when I took it off there were "crispy critters". A cap/resistor that had shorted. Again, probably not your issue, but don't forget to look under that shield.
Bryan |
I'm running, and working on, a CTC-7 with an original CYP22 in it.
When it's warming up, I get a momentary glow of blue in the neck of the CRT just as high voltage comes up. It's always gone before the screen lights. The 3A3, which is an original with the set glows blue for just a moment around the gap between the plate and cathode. This set is almost totally original... a total of 2 tubes replaced by me. Perfectly normal for me over the years.
Bruce Last edited by holmesuser01; 01-05-2016 at 10:18 PM. |
I had a CTC-31 with an intermittent connection in the video output section. When it would lose the video the neck of the crt would glow bright purple. The crt was fine.
Bryan |
Almost all 4 filter caps were completely fossilized. I restuffed the cans and now I have no HV with the chassis on the bench out of the cabinet. Dont see the 3a3 or the 1V2 glowing. everything else seems to be OK. No magic smoke just no HV at all I cant even hear any sort of high voltage whine from the flyback. I have been reading over the schematics and I cant seem to figure this out.
Tom's right, RCA's and probably others won't work with the yoke disconnected. I made an octal jumper plug to replace the yoke when I run sets on the bench, just for that reason. You can make one yourself, just break any useless octal tube and harvest the socket. Remove the remnants of the old lead wires, and jumper pins 3 and 7 together. Works on all RCA chassis CTC-2 through CTC-5. CTC-7 and later had spade connectors for the yoke, so the horizontal sections will run without jumpering anything.
Evolution... |
That did it. Thanks Nick! 6BK4 now has its spooky green glow again!
Changed the damper and H-out and now when hv comes up I get a bunch of weird sounds from the flyback lower pitched squeals. I put the original tubes back in and I still have this issue. Is the flyback going bad or is there arcing somewhere possibly.
The yoke which is a coil, makes up a tank circuit with a capacitor that makes up part
of the B+ Boost, and load on part of the flyback. All of these are tuned. Jumping a short across the coil on the yoke surly has an effect on the rest of the sweep circuits. Even if some have jumped something and not had anything go wrong, I would say it's not a good idea..... Especially if you are trying to troubleshoot something in that area of the set.... For your problem, you need to check to be sure items in the area are working as best you can... Voltages at the different points on the picture tube. (Bias - Gx pins, Focus, HV, Horiz output tube Cathode current in range, sweep circuits working, etc. ) .
Yes you can call me "Squirrel boy" Last edited by Username1; 01-08-2016 at 05:06 PM. |
But I find it odd that it would just now start this...
Squeals could be arcing, but also could be the H oscillator not running properly. An oscilloscope is really useful for checking this out.
Turns out the the new 6CG7 horiz osc had a short in it and so did the new damper. Replaced those with the originals and got my HV back. Is it normal for the HV to only measure 4-6 kilovolts without the crt or yoke plugged in? I am running the chassis on the bench.
I have no idea, but I'm not surprised. Running without the yoke doesn't seem wise, as the system is tuned to resonate one half cycle during retrace with the yoke connected, and it's hard to tell if disconnecting will put less or more stress on the horizontal output and damper. I think it would be worth the effort to make extender cables.
