Old 01-07-2016, 06:30 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Fast question on a Crosley 635
Doing a recap on this radio for a friend, and I hit a "question mark".
The set uses a 1 uF 160V cap, but do I replace it with an electrolytic or a mylar?
Link to Riders:
https://www.tubesandmore.com/schemat...osley-corp/635
Old 01-07-2016, 09:51 AM
init4fun's Avatar
init4fun init4fun is offline
Link to Riders:
Good question , my educated guess would be that either would work , I'm just not too sure which would have preference over the other ....
Old 01-07-2016, 12:49 PM
I would use a mylar! Then you don't have to worry about polarity.
Old 01-07-2016, 12:56 PM
I just looked at the schematic again!
If you used an electrolytic cap, the positive side would have to go to the chassis ground. It's a bypass for the neg bias line. I'd still go with the mylar.
Old 01-07-2016, 02:29 PM
The mylar should last longer than the electrolytic too.
Old 01-07-2016, 08:26 PM
Kamakiri's Avatar
And mylar it was...closest I had was a pair of .47 in parallel. Close enough, and works nicely . Thanks!
Old 01-13-2016, 08:23 PM
teevee's Avatar
teevee teevee is offline
I'd measure the voltage across it, (C21?) should only be about 15 or so? a small electrolytic would do nicely..
Old 01-14-2016, 09:27 AM
Kamakiri's Avatar
In this case, I don't need to.....it's now happily back with its owner and playing nicely
