Great save.
I think I have a set similar like this set. I agree.Those PITA Sony power cords.Panasonic follows,are a nightmare If you dont get the right pinout and voltage info . Pop goes the weasel. |
CRT's almost always fail due to low emission. On a
B&W symptoms are dark pix, negative pix, streaking of bright areas, slow warm up & overly bright whites with no detail or any combination of..... Best test is darken the room, turn down the bright & contrast. If it looks a lot better its the CRT 99%. All fixes are risky ( except a new CRT ) Rejuvenation, only use a MODERN CRT checker for this made after the early 70's. Brighteners only work on some sets. Most sets have a low ohm resistor in series with the filament. It can be jumped out to give a little more E but again risky. As far as waking it up goes regular use will usually improve things but its a process that goes on just like people getting old & slowing down...... 73 Zeno
