IIRC increasing the capacitance (IIRC by about double) of the high voltage vertical coupling caps is a cure for vertical linearity issues in electrostatic sets. If the vertical stage ceramics you replaced are good and of the right value, try tacking them in parallel with the mylars and see if linearity improves any.
-George- |
Since the coupling caps didn't help, the still-squashed raster shows the vert sawtooth having a slow rise-time. I would consult the schematic to see what R or C values might be adjusted to give a faster rise time without changing the sweep frequency.
