Old 02-29-2016, 04:40 PM
It's a non polarized cord.
Old 02-29-2016, 04:55 PM
WISCOJIM WISCOJIM is offline
Originally Posted by Farlander View Post
I was more of asking so I can know which cord to get polar or non-polar. But thanks for the info.
You can tell by looking at the interlock on the back of your chassis. If both prongs are identical in size, it's non-polarized. If one is larger than the other, in that case you would have needed a polarized cord.
Old 02-29-2016, 05:00 PM
Farlander Farlander is offline
Alright thanks also would rubber gloves help protect me from the high voltages?
Old 02-29-2016, 05:26 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Rubber gloves actually rated for electrical insulation would likely be too clumsy to do fine electronics work in. At least the pair I have...
I would suggest using your DMM to check the outlet you will be plugging into first, to make sure that it is properly wired (wider blade is neutral) and properly grounded. I would suggest using at least a GFCI receptacle if you want to skimp on an isolation transformer.
Marking the cord for polarity is a good idea. Installing a polarized interlock and cord is a better one.
Old 02-29-2016, 06:09 PM
Alright anyway I can figure out which side of the plug on the tv leads to chassis and which side goes to the rest of the circuits?
Old 02-29-2016, 07:02 PM
N2IXK's Avatar
Technohippie
Yes, you want the neutral side of the line to connect to the chassis.
Unfortunately, the set has the power switch in the grounded side of the line, which will make the chassis hot with respect to earth ground when the set is turned off.
To make such a set as safe as possible without major redesign, I would recommend the following:
Replace the interlock and cord with a polarized type.
Move the power switch to the hot side of the line.
Directly ground the neutral side of the line to the chassis.
Delete C85.
Replace C84 with a safety rated (X1Y2) ceramic cap.
Old 02-29-2016, 07:31 PM
Delete C85.
Should that capacitor have the same capacitance as the original or just anyy capacitance.
Old 02-29-2016, 08:41 PM
N2IXK's Avatar
Technohippie
Same as original is always best, but .05uF is a bit large for a ceramic type. You may need to go with a polystyrene film cap. Whichever you use, make sure it has the proper safety rating for across the line AC service.
This cap is used for RF bypass purposes, and isn't all that critical as far as capacitance value.
Old 02-29-2016, 09:19 PM
You can get safety rated caps from http://www.justradios.com/ , which also has a good article about the whys & wherefores of such caps:
http://www.justradios.com/safetytips.html
Regards,
Phil Nelson
Phil's Old Radios
Old 03-01-2016, 09:56 AM
I'm guessing the type I need is the "line to ground" variant?
Since N2IXK said it's for RF bypass.
Old 03-05-2016, 09:53 AM
New-old tv cleaning
I have been going over the Emerson I got (while waiting for the new power cord) and I have noticed that it seems like this tv was only used once in its life time, as all the tubes test like new (that I have gone through so far) and the crt looks perfect although dusty (like the rest of the inside).
Old 03-05-2016, 10:00 AM
This is the third thread you've started about the same TV. It helps others follow your story if you keep all chatter about a particular set in one thread. It's also far less annoying...
Old 03-05-2016, 10:38 AM
Oh sorry I don't really know how to delete the post so I will figure out how to get rid of it and re post this the other thread.
Old 03-05-2016, 11:29 AM
I merged all the posts together.
