The Fremodyne was a form of super-regenerative circuit, developed for inexpensive FM receivers. Heathkit, even made a kit form in the late 40's. It received FM stations, but it wasn't a true FM receiver. Fidelity wasn't that great, as it used some form of slope detection.
I'm not hearing any objections so I guess I will then try out some different colored bulbs then.
The candelabra-based 'Xmas tree' bulbs commonly used in 'nite light' applications are very short lived, unlike the originals. Even with a diode in series to run them at half power they burn out quickly.
SO basically any of the modern "nightlight" bulbs which is what this uses (except that the original was a 10 Watt bulb according to the Rider's service Information which they don't make 10 watt nightlight style bulbs anymore and the next closest would be either a 4 or 7 watt bulb.) what I would and could do is try and find a box of NOS C7 Christmas light bulbs (which they do show up quite often at the antique malls near me, especially around Christmas time) because it seems that's what you're saying by saying that the older ones lasted longer than the modern ones do.
In my experience, the 4 and 7 watters made in the last 30 years or so are very short lived.
The original 10 watters used in the 'Exit' signs in my building, installed in the 1960s, lasted a good 20 years before they started burning out. The only replacements available were the 4 and 7 watters, which required constant replacement until I finally got rid of them recently and put in LED retrofits. And BTW, before somebody hollers, I did not run the 'Exit' signs at half power. I ran a single bulb with a diode to test how long it would last, and it burned out almost as fast as without a diode. Last edited by old_coot88; 04-11-2016 at 10:36 PM. |
At the end, we installed LED signs with ni-cad battery backup. That's the kind, I have in my two buildings. |
I Use these LED bulbs on my vintage night-lights and radios that require a line volrage bulb. They work fine for me and run very cool (only .36 watts!).
http://www.amazon.com/G7-Power-Beatt...ight+led+bulbs not affiliated, jr |
You might be thinking of me. Mine was partial recapped and partially working when I received it. I haven't had a chance to finish restoring it yet.http://www.videokarma.org/showthread.php?t=260088 |
Luckily, it still has the original. The third wire ends just short of the plug. I'd use a modern three wire electrical cord with a two prong plug. Use the third "ground" wire for the antenna.
OK Thanks. That's what I was thinking of doing myself but I thought I would get a second opinion from someone on here first. I'll probably take a trip to the hardware store this afternoon and see if I can find the kind of cord I need.
