Old 04-19-2016, 03:49 PM
Hagstar's Avatar
Hagstar Hagstar is offline
Originally Posted by DaveWM View Post
So did you watch the videos? The key is to not watch a set until catches fire. As soon as arcing is happening that is the time when you still have a chance to fix the FLY. Based on your resistance readings you may be too far gone but there is no reason not to investigate.
I watched every video containing the word flyback on YouTube before even beginning to restore the set. I repeatedly followed the instructions given- encasing the flyback in non-acidic silicone twice. It suppressed the arcing but not internally.
John H.
Old 04-19-2016, 04:07 PM
John H.
Indeed, that was when the idea of using the hot wax and the vaccum to draw the moisture out before encapsulating it come up.
I think another option would be to use low heat and a desiccant to further draw the moisture out, although I think Shango's hot wax is the best.
I suggest you remove the silicone and examine the paper windings. When you orig did the silicone did you note any black marks showing burns on the paper insulator?
