Old 04-26-2016, 10:15 AM
earlyfilm's Avatar
Eternal Member
Originally Posted by Kamakiri View Post
I've got full raster, but no signal and no audio. I've got nothing on pin 3 of V1 (6AG5), and ~180V on pin 1 of V2 (12AT7). The overload on V2 is in the neighborhood of the voltage that I should have on V1 that's not there.
The only thing that connects the two pins directly is a small mica, which I robbed out of a parts chassis to no effect. I've done the obvious resistor and cap checks in the vicinity.
Forget your "golden screwdriver treatment" for the moment, you have a circuit wired wrong.
Pin 3 is a filament.
If rest of the set is working, that means the other tube's string filaments are lighting.
Unplug the set and ohm out the filaments in this area.
Pin three should have a choke and not a cap!
James
Old 04-26-2016, 12:47 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
James
Sure looked like it could've been a mica. In any event, I replaced it with the unit from a parts chassis that was in that exact spot, figuring that the likelihood of both being bad was negligible.
