Old 04-28-2016, 10:00 AM
Originally Posted by Captainclock View Post
Hello everyone, I have recently received from an older lady at church a couple of AM/FM Pocket Transistor Radios from about the early 1980s one is a GE Model 7-2582G and the other one has no model number but has the designation of Imperial BY SUPERSCOPE on the front of the case. Anyways I'm not too sure what the lady did to these radios if anything at all but both of these radios have the same exact issue and that is that they both have extremely distorted audio, its so badly distorted that the audio actually cuts in and out sometimes to the point that nothing can be heard at times. I'm just curious as to what might be causing these two completely different branded radios to have the same the same distorted audio issue.
Any help would be appreciated.
Thanks,
Levi
The GE probably has the entire radio-on-a-chip design, like the Superadios.
The other one is probably a more conventional design. My vote would go for dried out electrolytics.
Old 04-28-2016, 11:40 AM
Banned
Well the GE uses 4 electrolytics so it should be fairly straight forward to replace them, the other one however is got 8 electrolytics and is kind of a complicated design, I think you might be right about the GE being designed like a Superadio as far as having the entire radio on a chip design because I saw a small chip inside the GE radio that was within the tuner section of the radio, and it seemed to be fairly sensitive when you could hear something on it. I know Superscope was a fairly high end manufacturer back in the day from what I read so the Superscope radio should be a fairly good performer as well once its repaired.
UPDATE: I replaced the electrolytics in the GE Radio and it still has garbled and distorted audio so I'm not quite sure what to do next, I'm hoping its not one of the output transistors because if it is then its probably not going to be worth my time to repair it because those output transistors are quite expensive.
